Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
What does the AutoRestart API command do? I'm assuming it will restart an input if stopped at any time (versus the Restart command which just does it once on use)? So, is it actually sitting watching for an input to stop and then it will restart it on its own?
Thanks,
Fritz Golman RadioDNA
Hi. It would be perfect if it worked like you say.It would be very usefull for example for an srt source and also a trigger like "when/if stopped-->restart and do an action". Hope for vmix 29 But what it does is for the specific input to check/tick on-->meaning enable the "Automatically Restart with Transition"
Gotcha, there was no description in the Shortcut reference.
Thanks!
