JanekW31
#1 Posted : Tuesday, May 20, 2025 6:21:46 AM(UTC)
JanekW31
Germany
Hello everyone,
I have the following problem: I have a vMix show that decodes several SRT streams. Most of the time we have no problems, but occasionally it happens that individual SRT streams only work via the VLC plugin in vmix and not via the normal SRT caller feature. The problem with this is that the vlc plugin does not allow you to select the individual audio tracks.
Does anyone know a possible reason why some SRT streams cannot be decoded “normally” in vmix?
Best regards from Düsseldorf
Janek
nikosman88
#2 Posted : Tuesday, May 20, 2025 11:56:32 PM(UTC)
nikosman88
Greece
Hi. All the srt streams are produced by same machine/way? If not,ask the person how produces it and check if something can be changed in order to match your needs
Either than this,if you didnt try it,try to decode via sw or hw option in Vmix when add the srt input.
Peter1000
#3 Posted : Wednesday, May 21, 2025 3:08:19 PM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
there is a new SRT-Decoder Software from Haivision available. (WIndows/Mac/Linus)
Haivision Play ISR
The software is free and can display a lot of stream data, including metadata if available. It can also handle different audio tracks. Several instances can be started.
This should also display the differences between the various SRT streams from JanekW31.
ckvideo
#4 Posted : Sunday, June 22, 2025 8:55:46 AM(UTC)
ckvideo
Germany
Haivision Play ISR
you could also try Multistreamer to analyse things.
Also beware of the dreaded HEVC issue:
If in your SRT stream the video is in HEVC, the Windows installation needs to have the HEVC extension installed. Otherwise you have no video, only audio and no error message in vMix. You need to buy the extension in the MS-Store for 0,99 € (https://apps.microsoft.com/detail/9nmzlz57r3t7?hl=de-DE&gl=DE). vMix uses this for decoding. VLC however, has its own internal HEVC decoder. vMix outgoing streams however seem to use the FFMPEG H.265 encoder and do not the the extension to be installed.
Maybe this is the issue. VLC will also show you the video codecs used in the stream in the information window.
Good luck!
