MickeyMJJ
#1 Posted : Sunday, May 11, 2025 8:18:03 AM(UTC)
MickeyMJJ
Would it be possible to significantly improve the shortcuts interface?
Here are some suggestions:
- Ability to expand the window to full screen
- Ability to add the Description 1 and Description 2 columns
- Add another description field that could only be viewed in the Shortcuts window
- Ability to change the sort order by clicking on the column headers
- Ability to group shortcuts
- Modify the copy-paste behavior when selecting multiple shortcuts. Currently, when copying and pasting multiple shortcuts at the same time, the copy is inserted every other line
I think I have over 250 shortcuts currently. I sometimes have to double my Surface device (e.g., multiple StreamDecks), and when there are 30 shortcuts to copy and paste, it's hell.
spinfold
#2 Posted : Sunday, May 11, 2025 4:36:38 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: MickeyMJJ Go to Quoted Post
If you're already using StreamDecks I highly recommend forgetting entirely about vMix's built-in shortcuts, and instead using Companion.
Honestly, it will be a game changer for you.
MickeyMJJ
#3 Posted : Monday, May 12, 2025 4:05:38 AM(UTC)
MickeyMJJ
Thank you for your reply.
I've already asked myself this question and I think I'd like to switch to it.
But there's one feature of the StreamDeck software that I can't find a replacement for with Companion.
At events, I also use the StreamDeck as a soundbox. These audio files are directly managed by the StreamDeck software, where I can set a different volume for each sound, fade in or out, and choose whether the sound should stop, restart, or overlap when I press the same sound multiple times.
(Sorry if the translation is bad; I'm French and I use Google Translate.)
Similar Topics
Add tittle transition in and out in shorcut (Feature Requests)
by Johann973 9/19/2025 2:23:34 AM(UTC)
Shorcut: Visca PTZ Autoframing start/stop (Feature Requests)
by blackburst 6/25/2025 12:17:26 PM(UTC)
the list shorcuts dont work after input 300 (General Discussion)
by Bonete2 2/21/2025 5:13:09 PM(UTC)
Individual Buses (Master, A, B, etc) SetGain Shorcut (Feature Requests)
by Bonbondotkom 8/23/2023 3:46:55 PM(UTC)
Shorcut for Toggle Overlay "last input" not available. (General Discussion)
by salvaf 5/12/2022 8:28:13 AM(UTC)
More shorcut SHIFT + some key? (Feature Requests)
by Hall3008 9/3/2020 6:16:12 PM(UTC)
shorcut de vmix xkey xk60 (Instant Replay)
by Ameth E. Villarreal M. 8/20/2019 1:55:45 PM(UTC)
Start/Stop Video Delay Recording Shorcut&API (Feature Requests)
by Ernest Król 12/7/2013 12:05:53 PM(UTC)
