Joined: 12/14/2018(UTC) Posts: 162   Location: Clermont-Ferrand Thanks: 37 times Was thanked: 9 time(s) in 8 post(s)
Hello, Would it be possible to significantly improve the shortcuts interface? Here are some suggestions: - Ability to expand the window to full screen - Ability to add the Description 1 and Description 2 columns - Add another description field that could only be viewed in the Shortcuts window - Ability to change the sort order by clicking on the column headers - Ability to group shortcuts - Modify the copy-paste behavior when selecting multiple shortcuts. Currently, when copying and pasting multiple shortcuts at the same time, the copy is inserted every other line
I think I have over 250 shortcuts currently. I sometimes have to double my Surface device (e.g., multiple StreamDecks), and when there are 30 shortcuts to copy and paste, it's hell.
Joined: 1/23/2022(UTC) Posts: 131  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: MickeyMJJ  Hello, Would it be possible to significantly improve the shortcuts interface? Here are some suggestions: - Ability to expand the window to full screen - Ability to add the Description 1 and Description 2 columns - Add another description field that could only be viewed in the Shortcuts window - Ability to change the sort order by clicking on the column headers - Ability to group shortcuts - Modify the copy-paste behavior when selecting multiple shortcuts. Currently, when copying and pasting multiple shortcuts at the same time, the copy is inserted every other line
I think I have over 250 shortcuts currently. I sometimes have to double my Surface device (e.g., multiple StreamDecks), and when there are 30 shortcuts to copy and paste, it's hell. If you're already using StreamDecks I highly recommend forgetting entirely about vMix's built-in shortcuts, and instead using Companion. Honestly, it will be a game changer for you.
Originally Posted by: spinfold  Originally Posted by: MickeyMJJ  Hello, Would it be possible to significantly improve the shortcuts interface? Here are some suggestions: - Ability to expand the window to full screen - Ability to add the Description 1 and Description 2 columns - Add another description field that could only be viewed in the Shortcuts window - Ability to change the sort order by clicking on the column headers - Ability to group shortcuts - Modify the copy-paste behavior when selecting multiple shortcuts. Currently, when copying and pasting multiple shortcuts at the same time, the copy is inserted every other line
I think I have over 250 shortcuts currently. I sometimes have to double my Surface device (e.g., multiple StreamDecks), and when there are 30 shortcuts to copy and paste, it's hell. If you're already using StreamDecks I highly recommend forgetting entirely about vMix's built-in shortcuts, and instead using Companion. Honestly, it will be a game changer for you. Thank you for your reply. I've already asked myself this question and I think I'd like to switch to it. But there's one feature of the StreamDeck software that I can't find a replacement for with Companion. At events, I also use the StreamDeck as a soundbox. These audio files are directly managed by the StreamDeck software, where I can set a different volume for each sound, fade in or out, and choose whether the sound should stop, restart, or overlap when I press the same sound multiple times. (Sorry if the translation is bad; I'm French and I use Google Translate.)
