AlanZ
#1 Posted : Wednesday, May 7, 2025 1:41:12 AM(UTC)
AlanZ
For some time now, UVC connected Obsbot cameras no longer respond properly to vMix UVC PTZ Pan commands.
Tilt and Zoom commands work normally, but when issuing a pan command (either with a joystick or directly with the pan controls in the vMix ptz setting screen), sometimes there is a slight vertical tilt movement (unwanted), but most times, no movement at all.
I was under the impression that this was already reported by/to vMix and Obsbot.
This affects all obsbot cameras I have tested, and on multiple computers.
I have reproduced this problem on Obsbot Tail 2, Tail Air, Tiny 2, Tiny 2 Lite, and Tiny 4K.... all with the latest firmware.
Note that the my Insta360 Link works properly with vMix UVC PTC.
I have gotten reports from several other vMix 4K users, with the same problem.
Is there any update on fixing this problem?
vmixsupport
#2 Posted : Thursday, May 8, 2025 12:35:46 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Hi AlanZ. The issue has been reported to OBSBOT and is the result of a change in Windows Update 24H2. OBSBOT are yet to provide a fix.
AlanZ
#3 Posted : Thursday, May 8, 2025 2:06:54 PM(UTC)
AlanZ
Thanks for the update
