Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
For some time now, UVC connected Obsbot cameras no longer respond properly to vMix UVC PTZ Pan commands. Tilt and Zoom commands work normally, but when issuing a pan command (either with a joystick or directly with the pan controls in the vMix ptz setting screen), sometimes there is a slight vertical tilt movement (unwanted), but most times, no movement at all.
I was under the impression that this was already reported by/to vMix and Obsbot. This affects all obsbot cameras I have tested, and on multiple computers. I have reproduced this problem on Obsbot Tail 2, Tail Air, Tiny 2, Tiny 2 Lite, and Tiny 4K.... all with the latest firmware.
Note that the my Insta360 Link works properly with vMix UVC PTC.
I have gotten reports from several other vMix 4K users, with the same problem.
Is there any update on fixing this problem?
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 238 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 155 time(s) in 69 post(s)
Hi AlanZ. The issue has been reported to OBSBOT and is the result of a change in Windows Update 24H2. OBSBOT are yet to provide a fix.
