mortonc1
#1 Posted: : Saturday, April 19, 2025 6:25:22 PM(UTC)
mortonc1
New Zealand
I have 3 computers with Vmix on them and have made very complex titles that i have filled out so that the data sources have filled out about 60 different aspects of a title that are all autofilled and i want to get it going on the other computers aswell in the same way. is there any way that i can export these setting so that i dont have to re-do everything on the other computers.
i know you can save the presets and export them but it doesnt take the data source settings.
Is there any eassy way to do this?
THANBKS
nikosman88
#2 Posted : Sunday, April 20, 2025 12:22:13 AM(UTC)
nikosman88
Greece
Hi. Maybe im not understand something on what you need to do. If you have in the main vmix pc for example folders like E:\mytitles,presets,files etc and you make the exact same folders in sub-vmix pc`s.. You will have everything back
Or you can try the vmix save as-->bundle. I did a test with it and i see that datasources are active like the original preset.
mortonc1
#3 Posted : Sunday, April 20, 2025 6:13:47 AM(UTC)
mortonc1
New Zealand
Oh, I should specify i use different vmix presets on the other PC's as they do different jobs but I use some of the same Titles with the same data sources between them. So I just want a way to copy the set up from the title to a different presets title so I don't have to route the data sources to all the .text boxes and images again
