I have 3 computers with Vmix on them and have made very complex titles that i have filled out so that the data sources have filled out about 60 different aspects of a title that are all autofilled and i want to get it going on the other computers aswell in the same way. is there any way that i can export these setting so that i dont have to re-do everything on the other computers. i know you can save the presets and export them but it doesnt take the data source settings. Is there any eassy way to do this? THANBKS
Hi. Maybe im not understand something on what you need to do. If you have in the main vmix pc for example folders like E:\mytitles,presets,files etc and you make the exact same folders in sub-vmix pc`s.. You will have everything back Or you can try the vmix save as-->bundle. I did a test with it and i see that datasources are active like the original preset.
Oh, I should specify i use different vmix presets on the other PC's as they do different jobs but I use some of the same Titles with the same data sources between them. So I just want a way to copy the set up from the title to a different presets title so I don't have to route the data sources to all the .text boxes and images again
