SRT
SRT audio issues - very strange
Joined: 4/12/2025(UTC) Posts: 2  Location: London Thanks: 1 times
I set up vmix to receive SRT, as a caller. I'm using a 10-900x with vmix 28. I got this weird audio issue.
I assume it was internet, even though video was fine. I tested using 3 ISPs, 2 different firewalls. Same results. So not internet.
I tested on another PC 10-900x, same issue.
Tested on a laptop, it's i7 11-800H with vmix 26, same issue.
I had a friend test from another location on their laptop using vmix 24, works fine.
So then I installed SRT miniserver on my computer, that also works fine.
So everything points to vmix.
The feed I'm getting is H.264/50p @ 12mbps with stereo AAC.
My work around is to decode SRT in SRTMiniserver and tranmux to NDI in to vmix.
Joined: 3/28/2016(UTC) Posts: 169   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
So your saying it doesn't work with vmix 28 and 26 but does with 24 on a different machine and miniserver on your machine? What exactly is the problem you are having with audio? That might help a little more even though it works on your system with a different app. Does it work on your buddy system with avmix 26 or 28 or on your laptop at a different location? What about your system but with vmix 24? If you can explain the audio issue i could help with some better ideas to help narrow it down some. Originally Posted by: kierongarlic  I set up vmix to receive SRT, as a caller. I'm using a 10-900x with vmix 28. I got this weird audio issue.
 1 user thanked NiBTour for this useful post.
The audio issue was an intermittent drop, but very regular. Like it was a buffer issue, but like i said, video was solid. And latency adjustments made no difference. Originally Posted by: NiBTour  So your saying it doesn't work with vmix 28 and 26 but does with 24 on a different machine and miniserver on your machine? What exactly is the problem you are having with audio? That might help a little more even though it works on your system with a different app. Does it work on your buddy system with avmix 26 or 28 or on your laptop at a different location? What about your system but with vmix 24? If you can explain the audio issue i could help with some better ideas to help narrow it down some. Originally Posted by: kierongarlic  I set up vmix to receive SRT, as a caller. I'm using a 10-900x with vmix 28. I got this weird audio issue.
SRT
