Ario
#1 Posted : Monday, February 2, 2015 7:45:50 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Dear all,
loving the product and discovering more & more nice possibilities.
Now only if it would also be on Mac OS ...
My Q:
I use a BMD Intensity Extreme, capturing HDMI from a main cam, and delaying that 7 sec. so I can make highlight recordings via the overall Rec function, since I don't find the Delay-Save reliable.
This main cam goes to a YT livestream.
So far, so good. Using the delay in vMix 14, not vMix 15 (although I initially posted in that forum, incorrectly).
I need to look into audio-delay as well, but I think that will work.
BUT ... I have an IP-cam (Foscam, RTSP) as an overlay over the main cam, and that IP-cam needs to be in synch (scoreboard of a sports game), but I can't seem to delay the IP-cam feed.
Afaik, I can't delay it on the camera side, nor does delay work in Vmix.
I can set it, but it yields no result (apart from the slight delay that this type of feed 'always' seems to have).
Any advice?
I love the IP approach, so hoping to avoid having to switch to a digital cam+capture device.
Thanks & best,
Arie
richardgatarski
#2 Posted : Tuesday, February 3, 2015 3:35:08 AM(UTC)
richardgatarski
Arie,
Have you tried to increse the "buffer" on your IP cam's Stream Input? This will then be kind of a "delay". Not sure if it will be practical as the sync of IP cameras might drift over time depending on the quality of the network. But it might be worth a try.
Good luck!
Ario on 2/3/2015(UTC)
Ario
#3 Posted : Tuesday, February 3, 2015 9:44:12 AM(UTC)
Ario
Thanks Richard,
hadn't thought of that, definitely a good find & hence worth a try.
I will also experiment with the Vmix 15 beta with the new Instant Replay, maybe that works well enough to make my current issue obsolete.
Beta is available via
http://forums.vmix.com.a....aspx?g=posts&t=3283
Just hoping my laptop specs are high enough....
