Delay not possible on IP cam?
Thanks: 192 times Was thanked: 20 time(s) in 17 post(s)
Dear all, loving the product and discovering more & more nice possibilities. Now only if it would also be on Mac OS ...
My Q: I use a BMD Intensity Extreme, capturing HDMI from a main cam, and delaying that 7 sec. so I can make highlight recordings via the overall Rec function, since I don't find the Delay-Save reliable. This main cam goes to a YT livestream. So far, so good. Using the delay in vMix 14, not vMix 15 (although I initially posted in that forum, incorrectly). I need to look into audio-delay as well, but I think that will work.
BUT ... I have an IP-cam (Foscam, RTSP) as an overlay over the main cam, and that IP-cam needs to be in synch (scoreboard of a sports game), but I can't seem to delay the IP-cam feed. Afaik, I can't delay it on the camera side, nor does delay work in Vmix. I can set it, but it yields no result (apart from the slight delay that this type of feed 'always' seems to have).
Any advice? I love the IP approach, so hoping to avoid having to switch to a digital cam+capture device.
Thanks & best, Arie
Arie, Have you tried to increse the "buffer" on your IP cam's Stream Input? This will then be kind of a "delay". Not sure if it will be practical as the sync of IP cameras might drift over time depending on the quality of the network. But it might be worth a try. Good luck!
 1 user thanked richardgatarski for this useful post.
Thanks Richard, hadn't thought of that, definitely a good find & hence worth a try. I will also experiment with the Vmix 15 beta with the new Instant Replay, maybe that works well enough to make my current issue obsolete. Beta is available via http://forums.vmix.com.a....aspx?g=posts&t=3283Just hoping my laptop specs are high enough....
