Multiview on Fullscreen Monitor stuttering / lagging
I have an issue today that the Multiview (on Fullscreen Output 1) has some framerate issues. It is stuttering and lagging. Windows settings are OK for that monitor (1080p50). I never had that issue in the past. Could it be that there is a problem with a recent Windows update? I'm on Windows 11. The External SDI outputs are fine and don't show the issues.
Thanks and cheers
Robert
Strange. Have you tried to change the framerate in windows.
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Thanks and cheers
Robert I had the same issue, I tried setting the frame rate to match as suggested in other posts, but no improvement. And this is on a obsidian based system. So fortunately I had a BMD monitor card with HDMI & SDI out, so I connected that to my Multiview monitor and assigned output 3 to it. That worked perfectly.
