streaming---pro
#1 Posted : Tuesday, April 8, 2025 1:10:52 AM(UTC)
streaming---pro
Germany
I have an issue today that the Multiview (on Fullscreen Output 1) has some framerate issues. It is stuttering and lagging. Windows settings are OK for that monitor (1080p50). I never had that issue in the past. Could it be that there is a problem with a recent Windows update? I'm on Windows 11. The External SDI outputs are fine and don't show the issues.
Thanks and cheers
Robert
mavik
#2 Posted : Tuesday, April 8, 2025 2:19:27 AM(UTC)
mavik
Strange. Have you tried to change the framerate in windows.
Egriswold
#3 Posted : Friday, April 11, 2025 12:18:28 AM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Thanks and cheers
Robert
I had the same issue, I tried setting the frame rate to match as suggested in other posts, but no improvement. And this is on a obsidian based system. So fortunately I had a BMD monitor card with HDMI & SDI out, so I connected that to my Multiview monitor and assigned output 3 to it. That worked perfectly.
