artyomchebko
#1 Posted : Saturday, April 5, 2025 6:12:19 PM(UTC)
artyomchebko
Ukraine
Good day
tell me what could be the problem?
I'm adding a source CRT stream
it has 3 audio tracks
but none of them are displayed in the mix
for test i add this stream on intinor
and i have all audio tracksintinor
ac3 filter install
vmix 23 test
vmix 28 test
win 11
if i add srt stream live VLC srt steam
audio track 1-2 work but me need 3-4 =)
BARP
#2 Posted : Tuesday, April 8, 2025 8:28:42 AM(UTC)
BARP
It looks like your audio is in MPEG-2 codec, have you tried another audio codec like AAC, or LPCM? Alternatively what if you send a single audio stream with 8 channels, instead of 4 streams with 2 channels each?
artyomchebko
#3 Posted : Sunday, April 13, 2025 2:27:41 AM(UTC)
artyomchebko
Ukraine
Sorry
but I can't tell sports distributors what audio codecs to use!
I already contacted vmix support
and they confirmed that vmix only receives the AAC codec and in future releases they will probably fix this
ckvideo
#4 Posted : Tuesday, May 6, 2025 2:51:02 AM(UTC)
ckvideo
Germany
Sorry
when having trouble with streams/codecs/etc. I have good experience using Multistreamer as diagnosis tool. The test version runs 15 minutes with watermark, but can help you to look inside streams. If you pay a license, it can help you to convert things the way you need it.
Hope this helps !
