SRT
srt callier no sound
Good day tell me what could be the problem? I'm adding a source CRT stream it has 3 audio tracks but none of them are displayed in the mix for test i add this stream on intinor and i have all audio tracks  ac3 filter install vmix 23 test vmix 28 test win 11 if i add srt stream live VLC srt steam audio track 1-2 work but me need 3-4 =)
Joined: 10/14/2022(UTC) Posts: 20  Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
It looks like your audio is in MPEG-2 codec, have you tried another audio codec like AAC, or LPCM? Alternatively what if you send a single audio stream with 8 channels, instead of 4 streams with 2 channels each?
Originally Posted by: BARP  It looks like your audio is in MPEG-2 codec, have you tried another audio codec like AAC, or LPCM? Alternatively what if you send a single audio stream with 8 channels, instead of 4 streams with 2 channels each? Sorry but I can't tell sports distributors what audio codecs to use! I already contacted vmix support and they confirmed that vmix only receives the AAC codec and in future releases they will probably fix this
Joined: 3/21/2022(UTC) Posts: 47  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: artyomchebko  Originally Posted by: BARP  It looks like your audio is in MPEG-2 codec, have you tried another audio codec like AAC, or LPCM? Alternatively what if you send a single audio stream with 8 channels, instead of 4 streams with 2 channels each? Sorry but I can't tell sports distributors what audio codecs to use! I already contacted vmix support and they confirmed that vmix only receives the AAC codec and in future releases they will probably fix this Hi, when having trouble with streams/codecs/etc. I have good experience using Multistreamer as diagnosis tool. The test version runs 15 minutes with watermark, but can help you to look inside streams. If you pay a license, it can help you to convert things the way you need it. Hope this helps !
SRT
