random_julian
#1 Posted : Tuesday, March 18, 2025 11:18:33 PM(UTC)
random_julian
Germany
I am still having troubles getting my streamdeck (6.8.1 (21263)) to connect and work with my vmix (28.0).
Always when I press the streamdeck buttons the yellow exclamation marks appear and vmix doens't recognise the buttons.
I tried all fixes here in the forum (start vmix after streamdeck, deinstall both, change profile orders, klick on the button in streamdeck) but nothing works for me.
I am on a workstation in a big company. Might there be an IT resttriction for the connection between both? The log gives this error code:
ESDObsConnectionManager::CreateSocket::<lambda_4>::operator ()(): SLOBS returned error Verbindung verweigert
can anyone help pls?
dmwkr
#2 Posted : Tuesday, March 18, 2025 11:24:10 PM(UTC)
dmwkr
The error seems to be connected to OBS. Maybe uninstall the Streamdeck OBS plugin, and test again.
WaltG12
#3 Posted : Wednesday, March 19, 2025 5:06:42 AM(UTC)
WaltG12
You didn't mention if you've tried completely removing (as in also deleting the plugin files) and readding the vMix plugin within the Stream Deck software.
