Hardware Compatibility
Still Connection Problems with Vmix
I am still having troubles getting my streamdeck (6.8.1 (21263)) to connect and work with my vmix (28.0).
Always when I press the streamdeck buttons the yellow exclamation marks appear and vmix doens't recognise the buttons. I tried all fixes here in the forum (start vmix after streamdeck, deinstall both, change profile orders, klick on the button in streamdeck) but nothing works for me.
I am on a workstation in a big company. Might there be an IT resttriction for the connection between both? The log gives this error code:
ESDObsConnectionManager::CreateSocket::<lambda_4>::operator ()(): SLOBS returned error Verbindung verweigert
can anyone help pls?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
The error seems to be connected to OBS. Maybe uninstall the Streamdeck OBS plugin, and test again.
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
You didn't mention if you've tried completely removing (as in also deleting the plugin files) and readding the vMix plugin within the Stream Deck software.
