GT
Annimations from Data source?
Joined: 12/4/2018(UTC) Posts: 52  Location: Brussels Thanks: 3 times Was thanked: 11 time(s) in 11 post(s)
Hey, So I'm working on some new graphics for a client. For the sake of explaining lets say that it's a versus screen with a rotating team logo either side. We wanted to make this pull from the same match data set as our other graphics, so far so simple... however while I can see the image sequence in the title editor as a changeable source, If I change it to the first image of another teams logo the preview inside title editor updates but not the live image. So is it possible to dynamically link image sequences? I can think of a couple work arounds that aren't as efficient, but wondering if any one's come up against this and found a solution... or if this operator error and I've missed something. Thanks for any advice TT
**** Resolved ****
Ok just following up here. So I got it working. Turns out you need to do this from a data-source, you can't test it manually. So when you use a data source this does work.
GT
