TobinT
#1 Posted : Friday, March 14, 2025 8:47:25 PM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
Hey,
So I'm working on some new graphics for a client. For the sake of explaining lets say that it's a versus screen with a rotating team logo either side.
We wanted to make this pull from the same match data set as our other graphics, so far so simple... however while I can see the image sequence in the title editor as a changeable source, If I change it to the first image of another teams logo the preview inside title editor updates but not the live image. So is it possible to dynamically link image sequences?
I can think of a couple work arounds that aren't as efficient, but wondering if any one's come up against this and found a solution... or if this operator error and I've missed something.
Thanks for any advice
TT
TobinT
#2 Posted : Wednesday, April 9, 2025 7:06:38 PM(UTC)
TobinT
**** Resolved ****
Ok just following up here. So I got it working. Turns out you need to do this from a data-source, you can't test it manually. So when you use a data source this does work.
