John Hopkins
#1 Posted : Wednesday, March 12, 2025 9:19:20 AM(UTC)
John Hopkins
I have been using vMix HD version 26.0.0.44 on my Dell i7 8650 with 1TB SSD HD, 16GB DDR4
memory for over a year without problems.
I typically have 4 Elgato HD60 external video capture devices connected. One is receiving
"Easy Worship" from another computer and the other three have PTZ cameras connected.
I upgraded to the 4K version for the ISO / Multicorder function. It has worked fine for
around 3 months and I upgraded to version 28. Unfortunately this version needs more
resources than the computer has available. I removed it and re-installed version 26.0.0.44.
I can open a preset that does not include cameras and it will work fine but if I attempt to
add a camera I get the following message:
“Attempted to read or write protected memory. This is often an indication that other memory is corrupt.”
The options to "Send Error Message" or "Cancel" are provided in the error box. However, both
options will close vMix.
I have ran Windows Memory Trouble shooter and a hard disk tester to check for memory problems
but non were found.
I tried connecting only one video capture device and still received the same error message.
The internal webcam does load correctly.
nikosman88
#2 Posted : Wednesday, March 12, 2025 9:32:54 AM(UTC)
nikosman88
Greece
but non were found.
Hi .Has your pc updated to windows 11 24H2? If yes, try install vmix 26.0.0.46 or newer 26 if it exists.
ROBERTOBAHIA
#3 Posted : Wednesday, March 26, 2025 11:28:27 AM(UTC)
ROBERTOBAHIA
Philippines
i have this same problem... my windows version is 24H2... and my vmix license can only accommodate up to 24.0.0.72 x64 version of vmix
how can i resolve this? lifetime license?
thank you!
MickeyMJJ
#4 Posted : Wednesday, March 26, 2025 6:44:20 PM(UTC)
MickeyMJJ
To start, you need to update to vMix 28 which is better supported by the latest versions of Windows 11
