mg11
#1 Posted : Wednesday, March 12, 2025 3:05:50 AM(UTC)
mg11
Hello all! I am looking to hire someone for some vMix programming work or at least point me in the right direction!
I am currently working on a live stream project for a company in the automotive industry. Check out what I have so far here: [https://www.youtube.com/live/oRaaU5ch7lg?si=tOKKT6YAWzFz4Lvs]. Currently, all the feeds are SRT streams being pulled into vMix at my studio. It’s still a work in progress, but I see a lot of potential, especially with scaling the amount of cameras and shops along with getting the mobile setups going(via Larix Broadcaster app).
One thing I really would like to figure out is preventing the stream from cutting to empty shop bays. My idea is to use motion sensors in each bay, so if no movement is detected for a set amount of time, that camera feed in the playlist would be skipped. Can this be done with scripting or other high level automations?
If anyone is interested or you know someone who can do something like this please let me know!
Thanks!
#2 Posted : Wednesday, March 12, 2025 6:31:18 PM(UTC)
Thanks!
There are many angles to tacklle something like this or to consider.
Can vMix say read a motionsensor? yes with the right interface (arduino even) but your vMix system is at another location you say but you already have videofeeds that can be used
Are you going to use mobile phones (using larix)? might be better to look for another option like Mevo start cameras or so (can send srt and ndi).
Can vMix check motion? no but obs can (advanced scene switcher) and can then instruct vmix after you added some logic (macros) to it.
with multiple srt streams might look into srtminiserverto make your live easier handling them
Now only have to find logic to determine which feeds to show based on motiondetected (Past tense) or not etc ;-)
mg11 on 3/13/2025(UTC)
guidogast
#3 Posted : Thursday, June 5, 2025 9:31:11 PM(UTC)
guidogast
Netherlands
Was thanked: 36 time(s) in 24 post(s)
This can easily be achieved if you have something like Homey Pro. I think this can also be done with Home Assistant. Since vMix has a Web API, you can set the flows/automations up, so that when motion is detected, trigger a Web API call to vMix.
Is that an answer that is helping you, or are you looking for something different?
guidogast
#4 Posted : Saturday, June 21, 2025 10:59:55 PM(UTC)
guidogast
Netherlands
This post triggered me to mess around and see if I could make a vMix app for Homey Pro. Turned out to be much fun and wasn't that hard to create. It's currently published in Test mode. You can find it on the Homey App Store.
Guest (4)
