vMixAlot
#1 Posted : Wednesday, February 5, 2025 7:47:09 AM(UTC)
vMixAlot
A regular guest on video calls (the host of our show) can no longer successfully log into the studio. No issues before yesterday.
On logging in, he now sees a blue screen and then a small window with himself ( = camera working) overlaid on top of it.
I, the host, cannot see the guest in the studio either. Other guests do not have this issue, so somewhere there is an issue on his end that we've not been able to troubleshoot. He says he hasn't changed anything on his Windows PC laptop.
Unsuccessful fix attempts:
1) Updated Google Chrome to latest version.
2) Checked camera and mic permissions in Chrome are good.
3) Reduced Return Feed to guest to low (360p).
4) Enabled direct peer to peer connections.
5) Restarted VMix after all changes made.
6) Successfully logged in from his smartphone.
7) Speed test on internet: 19Mbps down and 19Mbps up.
8) Sent multiple new video call links.
Here are his call settings:
https://drive.google.com...CweX/view?usp=drive_link
https://drive.google.com...R-CJ/view?usp=drive_link
THank you
vmixsupport
#2 Posted : Wednesday, February 5, 2025 8:04:04 AM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
If they are using Chrome then it could be related to the issue with version 132 of Chrome. See the below knowledge base article link which explains this further:
https://www.vmix.com/knowledgeba...oogle-chrome-version-132
If they try Firefox and it works it would be the above issue. See the link on how to solve.
If not, please send us a support report via our contact form:
https://www.vmix.com/contact-us.aspx
