jeffmvr
#1 Posted : Wednesday, January 29, 2025 5:08:34 PM(UTC)
jeffmvr
Hi all,
As usual, amazing release with v28!
Currently there are variables returned by the API that can determine almost everything about a layer, such as the name, size, crop, number, etc. The ONE thing that is missing is whether the layer is enabled/disabled which determines whether it is shown or not.
Is there any way to add this?
Peter Berglund
#2 Posted : Wednesday, February 12, 2025 1:19:11 AM(UTC)
Peter Berglund
Sweden
+1
(I had a discussion with Skaarhoj as of today regarding this as I thought I discovered a bug related to feedback to their controllers. But they replied that it was only possible to enable/disable the layer through the API - no reporting back from vMix. So, yes, +1.)
/Peter
