	Feature Requests
	Add API variable for indicating whether a layer is enabled/disabled.
                Hi all,
  As usual, amazing release with v28!
  Currently there are variables returned by the API that can determine almost everything about a layer, such as the name, size, crop, number, etc. The ONE thing that is missing is whether the layer is enabled/disabled which determines whether it is shown or not.
  Is there any way to add this?
 Joined: 1/9/2019(UTC) Posts: 85   Location: Stockholm Thanks: 24 times Was thanked: 5 time(s) in 4 post(s)
                +1
  (I had a discussion with Skaarhoj as of today regarding this as I thought I discovered a bug related to feedback to their controllers. But they replied that it was only possible to enable/disable the layer through the API - no reporting back from vMix. So, yes, +1.)
  /Peter
	Feature Requests
