Feature Requests
Transition lenght in Ms, Fr(ames) or even better: in (S)econds
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 272 times Was thanked: 40 time(s) in 38 post(s)
It was once upon a time possible to input transition duration lenght in frames in the GUI? Or do I not remember corretly?
Either way it would be very welcome feature to current vMix line.
So for example with 25 fps project entering 50fr would give you a 2 seconds long transition.
Update: It would be even better if vMix could allow to use s(econds) like 0.5s, 2s, 60s so that the project frame rate is not in determining factor.
Joined: 2/23/2023(UTC) Posts: 91  Thanks: 29 times Was thanked: 20 time(s) in 6 post(s)
Exactly that is possible. Click the small arrow right at each transition and look at the buttom. There you can define the transition time in ms. By default 1000ms is selected.
Feature Requests
