jet
#1 Posted : Saturday, January 18, 2025 2:58:51 AM(UTC)
jet
Was thanked: 29 time(s) in 27 post(s)
It was once upon a time possible to input transition duration lenght in frames in the GUI? Or do I not remember corretly?
Either way it would be very welcome feature to current vMix line.
So for example with 25 fps project entering 50fr would give you a 2 seconds long transition.
Update: It would be even better if vMix could allow to use s(econds) like 0.5s, 2s, 60s so that the project frame rate is not in determining factor.
ryxyz
#2 Posted : Saturday, January 18, 2025 3:13:32 AM(UTC)
ryxyz
Was thanked: 20 time(s) in 6 post(s)
You might be thinking of the stinger configuration in the Overlay window.
mavik
#3 Posted : Sunday, January 26, 2025 2:04:56 AM(UTC)
mavik
Exactly that is possible. Click the small arrow right at each transition and look at the buttom. There you can define the transition time in ms. By default 1000ms is selected.
