AZyArt
#1 Posted : Thursday, January 16, 2025 7:54:14 PM(UTC)
AZyArt
Latvia
Hi there!
I have a some problem with an Instant Replay...
[Configure Instant Replay] the Cameras [1] - NDI camera, OK... and then press to record - nothing happening
[Configure Instant Replay] the Cameras [1] - Output 1 (where is same camera), OK... and then press to record - all is good and I can play a replay, also see calculations of how much time is remaining and is active time bar.
I was try to change folder, also tried another disc, checked the resolution, all seems correct...
What you think is it?
Thanks.
#2 Posted : Friday, January 17, 2025 6:27:56 AM(UTC)
@ AZyArt
Is it an NDI|HX Camera?
If so it is likely a poor or inconsistent NDI signal similar to why MultiCorder does not support such inconsistent signals from NDI|HX, Desktop Capture and vMix Call IP streams:
https://www.vmix.com/help27/MultiCorder.html
AZyArt on 1/17/2025(UTC)
AZyArt
#3 Posted : Friday, January 17, 2025 6:37:23 AM(UTC)
AZyArt
Latvia
Ohh... my fault, it is HX3
Seems like this, because I have a problem with an OBS studio and this NDI (there was freezes) only in vMix the camera works +/- good.
