Instant Replay
Does not start a NDI record
Hi there!
I have a some problem with an Instant Replay...
[Configure Instant Replay] the Cameras [1] - NDI camera, OK... and then press to record - nothing happening [Configure Instant Replay] the Cameras [1] - Output 1 (where is same camera), OK... and then press to record - all is good and I can play a replay, also see calculations of how much time is remaining and is active time bar.
I was try to change folder, also tried another disc, checked the resolution, all seems correct...
What you think is it?
Thanks.
@ AZyArt Is it an NDI|HX Camera? If so it is likely a poor or inconsistent NDI signal similar to why MultiCorder does not support such inconsistent signals from NDI|HX, Desktop Capture and vMix Call IP streams: https://www.vmix.com/help27/MultiCorder.htmlIce
Originally Posted by: IceStream  Is it an NDI|HX Camera? Ohh... my fault, it is HX3 Originally Posted by: IceStream  If so it is likely a poor or inconsistent NDI signal similar to why MultiCorder does not support such inconsistent signals from NDI|HX, Desktop Capture and vMix Call IP streams: Seems like this, because I have a problem with an OBS studio and this NDI (there was freezes) only in vMix the camera works +/- good.
Instant Replay
