Aki
#1 Posted : Friday, January 3, 2025 3:47:36 AM(UTC)
Aki
Was thanked: 4 time(s) in 1 post(s)
Hi
I have made a vmix script to log what's in vMix program (and the other mixes), and a corresponding software tool to convert the log into a EDL file you can import in DaVinci Resolve.
This way you can adjust all you cuts as needed.
You can also log markers while recording, and import these into DaVinci.
The software tool is used to read the script log and the multicoder log to syncs up the recordings, and to tie the EDL to the media filenames.
This is a small hobby project. So it is free, and with no guarantees. ;-)
It probably needs more testing, but should work fine.
You can find it here:
https://akisimonsen.wixsite.com/as-av-tools/vmix-logger
thanks 4 users thanked Aki for this useful post.
jet on 1/3/2025(UTC), nikosman88 on 1/4/2025(UTC), Brano on 1/10/2025(UTC), kuuminsh on 1/31/2025(UTC)
kuuminsh
#2 Posted : Tuesday, February 18, 2025 1:21:31 AM(UTC)
kuuminsh
Latvia
It's a shame that Adobe Premiere doesn't support Multi-camera via EDL.
When I have some free time, I'll look into how to split this script so that it runs on the space I used to do the CUT.
