melody
#1 Posted : Tuesday, January 27, 2015 8:30:44 AM(UTC)
Rank: Guest
Groups:
hello martin,
i would like to sugest an update for recording feature that makes possible to use an ftp server as a target for storage.
the ideas for ftp support are the following:
*realtime recording to an ftp server, just like a local recording;
*upload recording when finish/split;
*calculate best settings based on ftp recording feature, streaming feature and upload bandwidth;
*upload a jpg screenshot every "X" seconds to ftp server;
hope it can help a lot of users.
regards,
melody
www.espiritosanto.cc
gazreyn
#2 Posted : Tuesday, January 27, 2015 10:54:26 AM(UTC)
gazreyn
Was thanked: 9 time(s) in 6 post(s)
One temporary suggestion I have is to use a program called BitTorrent Sync. Provided you have full access over the server which you are running a web server from, you're able to run BitTorrent Sync on that PC and add a synced folder from the system being used to stream Vmix. This works by uploading/syncing with the folder on your web server whenever new files are put in to the local folder.
melody
#3 Posted : Tuesday, February 3, 2015 4:37:19 PM(UTC)
Rank: Guest
Groups:
thank you gazreyn, very good alternative.
