Feature Requests
ftp support for recording feature
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
hello martin, i would like to sugest an update for recording feature that makes possible to use an ftp server as a target for storage. the ideas for ftp support are the following: *realtime recording to an ftp server, just like a local recording; *upload recording when finish/split; *calculate best settings based on ftp recording feature, streaming feature and upload bandwidth; *upload a jpg screenshot every "X" seconds to ftp server; hope it can help a lot of users. regards, melody www.espiritosanto.cc
Joined: 4/18/2014(UTC) Posts: 55 Location: Birmingham, United Kingdom
Was thanked: 9 time(s) in 6 post(s)
One temporary suggestion I have is to use a program called BitTorrent Sync. Provided you have full access over the server which you are running a web server from, you're able to run BitTorrent Sync on that PC and add a synced folder from the system being used to stream Vmix. This works by uploading/syncing with the folder on your web server whenever new files are put in to the local folder.
Rank: Guest
thank you gazreyn, very good alternative.
Feature Requests
