fluozh
#1 Posted : Monday, December 23, 2024 4:32:01 PM(UTC)
fluozh
Japan
Hello.
We are using Mix for our production. But we realize CutDirect does not support Mix parameter. (Cut function does support Mix param)
Can we have Mix parameter option for CutDirect like Cut function? Thanks!
thanks 1 user thanked fluozh for this useful post.
vvcvvc on 12/27/2024(UTC)
Dist
#2 Posted : Thursday, December 26, 2024 11:31:38 PM(UTC)
Dist
Was thanked: 27 time(s) in 19 post(s)
Have you tried seeing if the ActiveInput function meets your needs? Much like CutDirect it allows you to send an Input directly to program without preview being change, but it also supports a Mix param so can be used with all Min inputs.
fluozh
#3 Posted : Sunday, December 29, 2024 12:36:10 AM(UTC)
fluozh
Japan
didn't know that function. Thank you so much Dist!
Also I was looking for function that sets Mix "None". It can be done though GUI but not from function afaik
