Feature Requests
Support Mix parameter for CutDirect function
Joined: 3/18/2021(UTC) Posts: 39   Location: Tokyo Thanks: 13 times Was thanked: 10 time(s) in 8 post(s)
Hello. We are using Mix for our production. But we realize CutDirect does not support Mix parameter. (Cut function does support Mix param)
Can we have Mix parameter option for CutDirect like Cut function? Thanks!
 1 user thanked fluozh for this useful post.
Joined: 12/19/2019(UTC) Posts: 62  Was thanked: 27 time(s) in 19 post(s)
Have you tried seeing if the ActiveInput function meets your needs? Much like CutDirect it allows you to send an Input directly to program without preview being change, but it also supports a Mix param so can be used with all Min inputs.
Originally Posted by: Dist  Have you tried seeing if the ActiveInput function meets your needs? Much like CutDirect it allows you to send an Input directly to program without preview being change, but it also supports a Mix param so can be used with all Min inputs. didn't know that function. Thank you so much Dist! Also I was looking for function that sets Mix "None". It can be done though GUI but not from function afaik
Feature Requests
