Brano
#1 Posted : Thursday, December 12, 2024 7:19:14 PM(UTC)
Brano
Allow using effects, e.g. color correction, LUTs, cropping, on Output.
Currently, I can loop the output back into an input, apply stuff there and set it to record/stream from it. But with this approach:
  1. I cannot see the applied oeffects on the program monitor
  2. If I change or swap inputs somehow so the loopback input changes its number, it is not automatically changed in the relevant settings for Ouput 1.
    So I may end up with unusable recording stream while seeing all good in the program monitor!
  3. I use LUTs on inputs for correction and a LUT on the output for grading
  4. It just make more sense to me to have stuff consistent across the software
