Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
Allow using effects, e.g. color correction, LUTs, cropping, on Output.
Currently, I can loop the output back into an input, apply stuff there and set it to record/stream from it. But with this approach: - I cannot see the applied oeffects on the program monitor
- If I change or swap inputs somehow so the loopback input changes its number, it is not automatically changed in the relevant settings for Ouput 1.
So I may end up with unusable recording stream while seeing all good in the program monitor!
- I use LUTs on inputs for correction and a LUT on the output for grading
- It just make more sense to me to have stuff consistent across the software
