Instant Replay
Replay out not to Output
Joined: 5/7/2024(UTC) Posts: 21  Thanks: 5 times Was thanked: 3 time(s) in 2 post(s)
Hi all. Apologise if this has already been answered, could not find a relevant topic.
Let me explain my basic setup.
VMIX 4k, so replay on 1 camera. We use ATEM Mini. We stream as normal via the Output channel.
But we also have a 2nd output going to a big screen in the venue, and this is set up as 'Input 2' and input 2 is fullscreen to the bigscreen, so we can switch inputs into Output 2 via Shortcuts (Activeinput into Mix 2). All that works fine
I can send a live feed from the ATEM to the Big Screen when I am playing adverts or something on the main live stream - all that works fine.
But we have a situation where we want to do a replay on the big screen only, but not on the main stream. Am i right in thinking any replay would be sent to OUTPUT (and therefore livestream)?
Is there a way to get a replay to just go on the Input 2 (Big Screen)?
Joined: 12/24/2021(UTC) Views messages in topic : 733  Location: athens Thanks: 166 times Was thanked: 100 time(s) in 96 post(s)
Hello. Im not familiar with instant replay as im not need it for my shows. But i see that if we do a mix input we can send to it the channel A or B (or both as pgm/pvw) and then assign this mix input as fullscreen out 1 or 2 the viewers of the fullscreen out tv device,will see the replay result without being this on livestream air
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: fcvideo  Am i right in thinking any replay would be sent to OUTPUT (and therefore livestream)?
That is correct ( if you are using "play events") Livestream, depends on what input/output you use
@ fcvideo
There are two Shortcut variants to be aware of: (a) ReplayPlayEvent (plays Event in Replay Input) (b) ReplayPlayEventToOutput (plays Event to main vMix Program Output with Stinger if set-up for that)
Instant Replay
