fcvideo
#1 Posted : Saturday, December 7, 2024 9:34:18 AM(UTC)
fcvideo
Hi all. Apologise if this has already been answered, could not find a relevant topic.
Let me explain my basic setup.
VMIX 4k, so replay on 1 camera. We use ATEM Mini. We stream as normal via the Output channel.
But we also have a 2nd output going to a big screen in the venue, and this is set up as 'Input 2' and input 2 is fullscreen to the bigscreen, so we can switch inputs into Output 2 via Shortcuts (Activeinput into Mix 2). All that works fine
I can send a live feed from the ATEM to the Big Screen when I am playing adverts or something on the main live stream - all that works fine.
But we have a situation where we want to do a replay on the big screen only, but not on the main stream. Am i right in thinking any replay would be sent to OUTPUT (and therefore livestream)?
Is there a way to get a replay to just go on the Input 2 (Big Screen)?
nikosman88
#2 Posted : Sunday, December 8, 2024 3:45:04 AM(UTC)
nikosman88
Greece
Hello. Im not familiar with instant replay as im not need it for my shows. But i see that if we do a mix input we can send to it the channel A or B (or both as pgm/pvw) and then assign this mix input as fullscreen out 1 or 2 the viewers of the fullscreen out tv device,will see the replay result without being this on livestream air
#3 Posted : Sunday, December 8, 2024 11:51:35 AM(UTC)
That is correct ( if you are using "play events")
Livestream, depends on what input/output you use
elvis55
#4 Posted : Sunday, December 8, 2024 9:48:14 PM(UTC)
elvis55
Switzerland
Export events to separate video files on the fly, or use the recordings straight away in your favourite video editor in MP4 or AVI format.
https://www.youtube.com/watch?v=l7l4MY9u7pA&t=1207s
#5 Posted : Sunday, December 8, 2024 10:36:36 PM(UTC)
@ fcvideo
There are two Shortcut variants to be aware of:
(a) ReplayPlayEvent (plays Event in Replay Input)
(b) ReplayPlayEventToOutput (plays Event to main vMix Program Output with Stinger if set-up for that)
