Joined: 6/14/2023(UTC) Posts: 28   Location: Melbourne
If I move my media to another drive (letter) I have to locate all media one by one, a tedious operation.
An option to change the relative path would work a treat - BlackMagics Fusion does this, its a game changer when there is tons of media.
I realise saving bundles is one way to do this, but when developing my VMix presets I usually save as a bundle when I am 95% there. Prior to that I am saving many versions of developing Preset.
Eg. If I have all my media stored in C:/MainFolder/Subfolder/LowerFolder/Media1/ and there is all my media folders under this ie Graphics, Titles, Movie Clips, Audio Clips etc.
If I move the Media1 folder to say D:/NewFolder/AnotherFolder/, a master relative alias path to re-point to new location would redirect VMix to look in new path - Can do a Save bundle from this point also if need be.
If above is not an option, then a maybe more dynamic 'locate' media that searches subfolder (Say from Media1 down) and finds the rest of the images. Adobe After Effects/Premiere and Resolume all do this, it's really efficient.
Or if that's not possible, then at least the ability to select more than one clip at a time to locate, sometimes I am using the same image in multiple clips, and have to locate the same image many times :( bit cumbersome.
If there is already a way to do this then I stand corrected/
Note, love VMix heaps, it's been a game changer for me!!
Joined: 12/14/2018(UTC) Posts: 162   Location: Clermont-Ferrand Thanks: 37 times Was thanked: 9 time(s) in 8 post(s)
+1 This would be really convenient when changing workstations.
To overcome this, on my side, all my files point to a folder tree that starts from a drive letter (example R:) using the subst command
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Just open the vmix file in an editor and search and replace. Really easy.
Originally Posted by: mavik  Just open the vmix file in an editor and search and replace. Really easy. I didnt know you could open it in editor, thanks for tip. I have tried it and it works. Though would still be a great simple function to implement in Settings.
No worries. Sometimes life isn't too complicated. Another reason why vMix is the best.
