offroadmediagroup
#1 Posted : Wednesday, November 6, 2024 3:49:33 AM(UTC)
offroadmediagroup
When you separate an input's "Channel" setting to "SeperateMono" (should be "Separate Mono Tracks"), the Shortcut for "SetVolume" only controls the Left channel and there's no explicit option for either Left or Right. If there's only one track, adding a "Mono Sum" checkbox would be a huge bonus. The only way to do this currently is to do the "SeparateMono" option... but if it's in the Right channel, you do not have Shortcut control over it and it has to be a manual point-and-click adjustment.
Please either add the Mono Sum and/or the option to control the individual split tracks via Shortcuts/Activators.
dmwkr
#2 Posted : Wednesday, November 6, 2024 7:32:49 AM(UTC)
dmwkr
SetVolumeChannel1
When using SeparateMono on an Audio Input, this can be used to set channel volumes independently.
https://www.vmix.com/hel...utFunctionReference.html
offroadmediagroup
#3 Posted : Wednesday, November 6, 2024 7:38:16 AM(UTC)
offroadmediagroup
Originally Posted by: dmwkr Go to Quoted Post
SetVolumeChannel1
Should I delete this or is there a better way to close a req?
Guest (4)
