Feature Requests
Add Split Audio Controls via Shortcuts along with Mono Sum
Joined: 9/7/2024(UTC) Posts: 64  Location: The Great PNW Was thanked: 10 time(s) in 9 post(s)
When you separate an input's "Channel" setting to "SeperateMono" (should be "Separate Mono Tracks"), the Shortcut for "SetVolume" only controls the Left channel and there's no explicit option for either Left or Right. If there's only one track, adding a "Mono Sum" checkbox would be a huge bonus. The only way to do this currently is to do the "SeparateMono" option... but if it's in the Right channel, you do not have Shortcut control over it and it has to be a manual point-and-click adjustment.
Please either add the Mono Sum and/or the option to control the individual split tracks via Shortcuts/Activators.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: dmwkr  Should I delete this or is there a better way to close a req?
Feature Requests
