Hi i am using the Vmix 4k version , it was working perfect but when i update the latest version of Vmix (27.0.0.85), i start face a performance problem especially when i add a website input , i am using rtx3060 , each website input increase the performance around 30% or more . is it a bug in the update or how can i solve the problem? note:in the performance setting i choose high input performance mode and i choose in the graphic adapter my nvidea rtx 3060 card Best regards
Joined: 1/11/2024(UTC) Posts: 25  Location: Mississippi Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
my problem not in gpu performance the problem come in the cpu performance , my gpu performance in just 15% , the problem in the cpu before the update it was working fine , just when i upgrade to the latestversion i face this problem
Joined: 11/23/2020(UTC) Posts: 249  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: saadeddine  my problem not in gpu performance the problem come in the cpu performance , my gpu performance in just 15% , the problem in the cpu before the update it was working fine , just when i upgrade to the latestversion i face this problem Then what is your CPU? How many inputs are you running? If you run Task Manager alongside vMix with your multiple web browser inputs open what does Task Manager show is using all of your CPU?
