saadeddine
#1 Posted : Monday, October 21, 2024 11:49:41 AM(UTC)
saadeddine
Qatar
Hi i am using the Vmix 4k version , it was working perfect but when i update the latest version of Vmix (27.0.0.85), i start face a performance problem especially when i add a website input , i am using rtx3060 , each website input increase the performance around 30% or more .
is it a bug in the update or how can i solve the problem?
note:in the performance setting i choose high input performance mode and i choose in the graphic adapter my nvidea rtx 3060 card
Best regards
bpscarbrough
#2 Posted : Monday, October 21, 2024 12:15:21 PM(UTC)
bpscarbrough
With a 3000 series GPU, you should have resizeable BAR enabled meaning you don't need high input performance mode.
https://www.vmix.com/kno...th-resizable-bar-support
saadeddine
#3 Posted : Monday, October 21, 2024 12:51:24 PM(UTC)
saadeddine
Qatar
my problem not in gpu performance
the problem come in the cpu performance , my gpu performance in just 15% , the problem in the cpu
before the update it was working fine , just when i upgrade to the latestversion i face this problem
Roy Sinclair
#4 Posted : Thursday, October 24, 2024 7:11:33 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Then what is your CPU?
How many inputs are you running?
If you run Task Manager alongside vMix with your multiple web browser inputs open what does Task Manager show is using all of your CPU?
Similar Topics
Editing vMix AVI in Premiere performance problems (General Discussion)
by aircooled76@gmail.com 4/17/2024 12:46:35 PM(UTC)
Performance Problems on High Level Production (Systems)
by SPONTENT 11/16/2021 1:01:14 AM(UTC)
