talrmd
#1 Posted : Wednesday, October 16, 2024 5:08:54 AM(UTC)
talrmd
I attached my USB Huddlecam HD. The camera initially shows up fine, but then the input (camera) turns grey. Please advise, Thank you!
sinc747
#2 Posted : Friday, October 18, 2024 3:30:42 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Are you connecting to a USB 2.0 port?
- Tom
talrmd
#3 Posted: : Friday, October 18, 2024 4:31:24 AM(UTC)
talrmd
Hi Tom,
Thanks for your response.
I'm connecting USB 3.0 port
congoblue
#4 Posted : Thursday, November 28, 2024 2:35:52 AM(UTC)
congoblue
Hi, I have one of these cameras. It is quite power hungry, are you using the original (quite thick) usb 3.0 cable that came with the camera? I tried to use a longer cable and had exactly the problem you are describing. Going back to the caable supplied with the camera, worked fine again. I think it is some sort of power problem.
