Rank:: Newbie
Joined: 4/22/2020(UTC) Posts: 8  Location: Fort Worth Thanks: 7 times
I attached my USB Huddlecam HD. The camera initially shows up fine, but then the input (camera) turns grey. Please advise, Thank you!
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Are you connecting to a USB 2.0 port?
- Tom
Rank:: Newbie
Hi Tom,
Thanks for your response.
I'm connecting USB 3.0 port
Joined: 10/30/2023(UTC) Posts: 38  Location: Hull Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Hi, I have one of these cameras. It is quite power hungry, are you using the original (quite thick) usb 3.0 cable that came with the camera? I tried to use a longer cable and had exactly the problem you are describing. Going back to the caable supplied with the camera, worked fine again. I think it is some sort of power problem.
