Salleman
#1 Posted : Wednesday, October 2, 2024 7:00:01 PM(UTC)
Salleman
Sweden
When using multiple Streamdecks and shortcuts long time passes hundreds of them, it should be nice with a function to highligth all shortcuts with same shortkey.
Today its just red if shortcuts sharing same key, but a function if I press a key and all shortcuts using this key is highlighted.
Then I can just fastscroll down the list to find cuts using this key.
#2 Posted : Wednesday, October 2, 2024 7:59:37 PM(UTC)
if one uses the find option the searched keys are all highlighted (be it with a light grey bar)
Salleman
#3 Posted : Wednesday, October 2, 2024 8:04:34 PM(UTC)
Salleman
Sweden
How could I have missed that?
Thanks, it's just as you said very, very light gray, but they are there....
WaltG12
#4 Posted : Saturday, October 12, 2024 6:12:08 AM(UTC)
WaltG12
I've used that feature and I'm only just now learning that it highlights all of them.
I could barely see it and assumed it was only highlighting the first one it found.
MickeyMJJ
#5 Posted : Monday, October 21, 2024 6:29:58 PM(UTC)
MickeyMJJ
Regarding shortcuts and when you have a lot of them, it could be very practical to be able to create categories in order to gather the shortcuts of the same theme.
