Feature Requests
Identify or sort shortcuts by shortkey
Joined: 3/13/2020(UTC) Posts: 38  Location: Stockholm Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
When using multiple Streamdecks and shortcuts long time passes hundreds of them, it should be nice with a function to highligth all shortcuts with same shortkey.
Today its just red if shortcuts sharing same key, but a function if I press a key and all shortcuts using this key is highlighted. Then I can just fastscroll down the list to find cuts using this key.
Originally Posted by: Salleman  When using multiple Streamdecks and shortcuts long time passes hundreds of them, it should be nice with a function to highligth all shortcuts with same shortkey.
Today its just red if shortcuts sharing same key, but a function if I press a key and all shortcuts using this key is highlighted. Then I can just fastscroll down the list to find cuts using this key. if one uses the find option the searched keys are all highlighted (be it with a light grey bar)
Originally Posted by: doggy  Originally Posted by: Salleman  When using multiple Streamdecks and shortcuts long time passes hundreds of them, it should be nice with a function to highligth all shortcuts with same shortkey.
Today its just red if shortcuts sharing same key, but a function if I press a key and all shortcuts using this key is highlighted. Then I can just fastscroll down the list to find cuts using this key. if one uses the find option the searched keys are all highlighted (be it with a light grey bar) How could I have missed that? Thanks, it's just as you said very, very light gray, but they are there....
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: Salleman  How could I have missed that? Thanks, it's just as you said very, very light gray, but they are there.... I've used that feature and I'm only just now learning that it highlights all of them. I could barely see it and assumed it was only highlighting the first one it found.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Regarding shortcuts and when you have a lot of them, it could be very practical to be able to create categories in order to gather the shortcuts of the same theme.
Feature Requests
