spinfold
#1 Posted : Saturday, September 14, 2024 5:38:43 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
I've just seen the IBC video showing vMix 28 features and was excited for the flatten layers feature, which I've been begging for for years!
However I just wanted to confirm that the flattened layer will be available as a layer on *other* inputs in the project, as a flat layer available to crop, zoom, etc the whole image?
(Currently the only way to do this is to put it through an Output or a Mix)
This is the most exciting thing for me in v28! THANKYOU!
#2 Posted : Saturday, September 14, 2024 6:06:36 AM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
It's simply a convenience feature, as it still uses a special hidden Mix input behind the scenes.
So you can see how it would work by simply using the existing Mix input workflow available now.
spinfold on 9/14/2024(UTC), nikosman88 on 9/14/2024(UTC)
spinfold
#3 Posted : Saturday, September 14, 2024 6:24:33 AM(UTC)
spinfold
So does it use a Mix input per flattened layer still?
WaltG12
#4 Posted : Saturday, September 14, 2024 6:48:28 AM(UTC)
WaltG12
More specifically, does flattening cut into the limit of 15 Mix inputs? Or impact Mix numbers used in shortcuts or scripting?
#5 Posted : Saturday, September 14, 2024 5:36:12 PM(UTC)
The hidden mix input is used instead of the source input when selecting the source as a layer of another input.
It does not count towards the normal Mix input total.
spinfold
#6 Posted : Saturday, September 14, 2024 5:50:36 PM(UTC)
spinfold
Awesome - THANKYOU!
