babouche59
#1 Posted : Wednesday, September 11, 2024 9:51:45 PM(UTC)
babouche59
I have a configuration where I use Vmix in video player (with lists) with a Atem Switcher. I use Companion to have autoplay (with companion trigger).
My problem is : with companion, the only command I found is "vmix: Media - Playback Actions" with a play on Input. I would like to have the same command for the list that is on program, not on specific input...
is there another command in companion or a tcp command?
Capture d'ecran 2024-09-11 134842.png (84kb) downloaded 19 time(s).
Thank's
nikosman88
#2 Posted : Wednesday, September 11, 2024 10:05:47 PM(UTC)
nikosman88
Greece
Hello. For the active/pgm output give as value -1
babouche59
#3 Posted : Wednesday, September 11, 2024 11:16:43 PM(UTC)
babouche59
Top, thank's a lot.
Have a good day!
Roberto
#4 Posted : Friday, July 4, 2025 3:22:33 AM(UTC)
Roberto
Brazil
Hello babouche59
Have you success on this workflow?
I'm trying the same workflow without results(vMix play do not work when I select it on the Atem panel)
Test action on Companion works on the vMix play.
