Command play to active list
Hi, I have a configuration where I use Vmix in video player (with lists) with a Atem Switcher. I use Companion to have autoplay (with companion trigger). My problem is : with companion, the only command I found is "vmix: Media - Playback Actions" with a play on Input. I would like to have the same command for the list that is on program, not on specific input... is there another command in companion or a tcp command?  Capture d'ecran 2024-09-11 134842.png (84kb) downloaded 19 time(s).Thank's
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Hello. For the active/pgm output give as value -1
Top, thank's a lot.
Have a good day!
Hello babouche59
Have you success on this workflow? I'm trying the same workflow without results(vMix play do not work when I select it on the Atem panel) Test action on Companion works on the vMix play.
