Dave Galegor
#1 Posted : Thursday, July 18, 2024 7:41:43 AM(UTC)
Dave Galegor
I need some help with the multi-coder.
I have been recording 3 rooms, when I take the files and load them in VLC media player, they work fine.
But when I try to load them into either Vegas or Davinci Resolve to edit, I get the not compatible file notice.
I have tried all 4 formats (AV -MPEG-etc) and no luck.
I have tried it on 2 different computer systems with the same result.
I would appreciate any help. Thank you.
Luis70
#2 Posted : Thursday, July 18, 2024 1:20:35 PM(UTC)
Luis70
Grenada
I had a similar issue, and I raised the video bitrate to 50 and got the clips to work in Edius....try that and see if it works for your editing software
